par WoestWatje » 29 Mar 2022, 08:29
Hi, I had a question regarding editing .dds files in paint.net. When I edit existing _D equipment files and save them, they appear pink ingame. I assume that paint.net saves the .dds files with other properties than they originally were. Even the slightest changes cause this problem
WoestWatje
- Débutant
par Froomeyy » 29 Mar 2022, 11:15
This is usually due to the registration being in .png and not .dds.
The problem does not come from paint.net which records well in .dds.
Froomeyy
- Directeur sportif
par WoestWatje » 29 Mar 2022, 11:32
What do you exactly mean? I know that with .png sometimes files get bugged when their bit depth is too low, but I don't see how this affects this problem. I'm using .dds files and also saving them back to .dds files. These are the default settings that I use now to save it.
WoestWatje
- Débutant
par Froomeyy » 29 Mar 2022, 11:59
You have to save it like this :
I should point out that all Cyanide equipments are saved in this format.
Froomeyy
- Directeur sportif
par WoestWatje » 29 Mar 2022, 12:56
Thanks, in the meanwhile I found another solution that worked; change the first setting to B8G8R8A8 (Linear, A8R8G8B8). I guess both ways work
WoestWatje
- Débutant
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 10 invités
