Thank you Sazee! Gazipasa and Alanya are on my list after the Tour of MersinSazee a écrit:Still fantastic, you can look at GP Gazipasa and Alanya, you have some zcts because your Tour of Cartier
clamel a écrit:I'm out of praising now. One great race after the other. It's just stunning that you keep cranking out these "missed" races.
Luckily you stay in pcm17 (with pcm18 added IBs) so that BOTH folks in pcm17 and pcm18 can play them.
So sad to see some new races done in pcm18 that is not working for pcm17. This is a shame that has plagued this game over the years. Some nice rcaes in the past when stage-creators never added zcts-files are lost in new versions.
You cover both angles. The ability to play both pcm17 pcm18 and hopefully the added zcts files can be used for future versions (at least I hope so). With Flo76 you have filled so many gaps in the ever growing cycling schedules which we players are for ever gratefull for. Not forgetting several other stage-creators (too many to mention) in the process but for now you two are the ones producing in a stunning speed.
My thanks
JorgeFerreira a écrit:Its possible add races to and existing career mode? I want to add Black Sea if possible, do you know Il Lince?
Wings a écrit:Wonderful work ! Running out of ID Stage at this point xD
Flo76 a écrit:I know lot of tools for produce speed and clean, but your work is very amazing, i think you spend much time on the SE i hope you will continue to produce a lot with the time !
clamel a écrit:You're a beast mate
Last of the Turks, wow. You forgot some in the calender. Do I really dare say that. Shame on me.
Tour of Fatih Sultan Mehmet
Tour of Antalya
But then you might cover them later I hope
You produce these beauties faster than I can add them and create XML for correct intermediates/KOMs for them.
I trust you indeed have put the correct categories on them so I don't have to make adjustment extraordinare.
Several of them have only type of KOM, if you get my idea, but if you indeed put different categories on those I just set same points to all categories. When I got better time to really test out and finalized the XMLs I will let you know if I ran into any difficulties.
Keep them coming mate. Forever gratefull.
Il lince a écrit:Flo76 a écrit:I know lot of tools for produce speed and clean, but your work is very amazing, i think you spend much time on the SE i hope you will continue to produce a lot with the time !
Hello Flo!
Thank You so much.
It´s true I spend to much time with the SE, much more time than with my wife but I have fun.
Over the time I became faster and faster and now that I know the little secrets, I do it more faster
You are planning the new tour of Oman? Now you are an honorary citizen of Oman
Flo76 a écrit:Il lince a écrit:Flo76 a écrit:I know lot of tools for produce speed and clean, but your work is very amazing, i think you spend much time on the SE i hope you will continue to produce a lot with the time !
Hello Flo!
Thank You so much.
The 2019's tour of Oman, or the tour of Oman v2.0 ?
Il lince a écrit:Flo76 a écrit:Il lince a écrit:Flo76 a écrit:I know lot of tools for produce speed and clean, but your work is very amazing, i think you spend much time on the SE i hope you will continue to produce a lot with the time !
Hello Flo!
Thank You so much.
I mean the official 2019 Oman. I have see that this year the race will have a second big climb
Flo76 a écrit:Il lince a écrit:Flo76 a écrit:Il lince a écrit:Flo76 a écrit:I know lot of tools for produce speed and clean, but your work is very amazing, i think you spend much time on the SE i hope you will continue to produce a lot with the time !
Hello Flo!
Thank You so much.
Yes i have plan the 2019's tour of Oman and i have make 3 on 6 stages, and the fourth have crash so i stop after this problem.
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 5 invités
